RE: FAST TUNNELS??
just curious, why not a bigger motor? You can setup a 700 or brushless for a 24" tunnel and it would run like hell.
As for the Budlight Tunnel, is it the MRP? Cause if it is, it should be running a 550 if it's stock. If that's what it is you could upgrade that OB unit and run a brushless set in it.
