RCU Forums - View Single Post - Engine stalls when plane is climbing
Old 09-22-2006 | 11:17 PM
ArCeeFlyer's Avatar
ArCeeFlyer
Default RE: Engine stalls when plane is climbing
My thoughts as well. The low end needle really shouldn't have much effect, if any, on the high end throttle. Strange. If you're throttling up from mid range to go vertical and the low end was rich enough to keep the engine from winding up, then it should have been worse on level flight.
