RCU Forums - View Single Post - STUFFING BOX TO PLASTIC BONDING MATERIAL
Old 09-23-2006 | 10:54 AM
Tug Guy
Default RE: STUFFING BOX TO PLASTIC BONDING MATERIAL
First off before any glue process begins the plastic should be washed off with soap and water then with Alcohol. This will remove any chance of a release agent clinging to the plastic. Then the area any glue will touch should be sanded on both sides. What I have used in the past and is still holding today after over 12 years is Araldite epoxy structural adhesive. It is also known as Fastweld #10. This adhesive does hold to plastic.
