Hi Tachikaze (hope I spelled that right)
On the Rivadavia, I've got 4 guns, and I can finally say they are all fully operational. WHOOPEE!! I'm using team delta relays hooked into my receiver and I've installed push buttons switches on the side of my transmitter. I've got 3 buttons to operate four guns and I only need one finger to do this. One of the buttons fires two barrels at once, some folks in MWCI have them hooked up to triples too. Using team delta relays you can activate two sets of guns per channel. My rate of fire is about 1 to 2 shots per second, kinda like a semi-auto, but ammo is limited. The Rivadavia can carry up to 225 bb's and would need most of that to put down a ship of equal size. Our bilge pumps don't have any actual volume restriction, but they do have limits on motor size, outlet discharge diameter, and limited to one pump rotor. I can push out 2-3 gpm using a scorpion motor on my pump.
Paul (aircoffee)
