RCU Forums - View Single Post - Interference prob with RCS140
Old 09-23-2006 | 12:51 PM
dirtybird
Default RE: Interference prob with RCS140
The CM-6 plug is not resistive. You will need a fully shielded system. When you hold your hand on the plug cap the problem goes away proves that the cap is simply not making proper contact with spark plug.
My 140 came with a small hose clamp to put around the cap at the base of the plug to hold the cap firmly in place. It needed that clamp.
