RCU Forums - View Single Post - The Mosquitos are here!!
Old 09-23-2006 | 01:16 PM
micro_builder's Avatar
micro_builder
Default RE: The Mosquitos are here!!
i just picked one of these up today as well. very very cool. i might be a bit biased, as i've been a fan of the BladeRunner line of helis since they first came out, but this one is certainly the coolest. very quite, more stable feeling than the other BR helis, and its pretty small too. 70 bucks is kinda steep, and there's been some bad reviews, but thats to be expected with some new toys.
lots of little modification options too, they give you two differant props for the tail motor, some little weights for the front for even more forward speed. doing the spacer mod should still work just fine, shedding some of the plastic to drop a few grams, and of course lube it well. no pictures as of yet, but i'll get some soon with some flight times and probably some video as well. what i'm looking forward to the most is when the stock motors die (they should actually last quite a while), cause once the stock ones go out, then i can start trying some of the differant SuperSlick 7mm motors and make it a hotrod
all radio shacks should have them in stock now, if not very soon. by the time christmas comes around, the price should be down and they'll probably have worked out some kinks so it'll be even better.
nick
