RCU Forums - View Single Post - Putting on steel clevis's?
Old 09-23-2006 | 11:08 PM
horace315's Avatar
horace315
My Feedback: (15)
Default RE: Putting on steel clevis's?
just make sure the threads on the rods you are using are 256 also,most metal ones i have used do fit a little loose.i use the plastic ones and haven't had any problems with those,but if you are flying a fast or aerobatic type plane i think i would use either soldered or metal ones with lock nuts.i also always use fuel tubing at the clevis after i connect them it holds them tight and keeps them from coming loose.
