RCU Forums - View Single Post - most powerful engine
Old 09-24-2006 | 12:46 AM
SManMTB's Avatar
SManMTB
Default RE: most powerful engine
ORIGINAL: 125cchyperman
I mean it should be good on seeing what engine is more powereful then another because they did it all on the same dyno. (I'm going off of your words on that)
I did already say that. But as in the numbers it means nothing. It is good for comparison, but thats about it. other then comparison it's not worth a dime, or a chewed piece of gum. Remember that dyno's are run in a room thats has the best ambient temps among other things. It does not show any chart, to look at and compare from that point. Remember that engine are much more then just numbers and if you make your decision sololy based on just nembers then you could be in for a rude awakening.
Thats just a thought.
I too would like to see the torque/hp curves but besides that what more can you ask for? Measured numbers are measured numbers and it's a good thing all engines were ran at the same ambient conditions.
