ORIGINAL: dick Hanson
OK- you tell me why it works -using wind tunnel data .
Believe it ot not you don't need tunnel data to make something work.
Lots of stuff that was designed by wind tunnel research turned out to be a flop.
NOT because of the tunnel - simply because real world use shows up flaws that paper work and controlled enviroments don't/ can't / never will.
Tunnels beat guesswork - I am not a fool.
I never alluded to any explanation of why the stuff works - simply that it does work-
You have to do actual hands on stuff , eventually .
Where are you going to get a tunnel which runs at 10 mph airflow ?
I guess they exist - I don't kno who uses em tho -
You really don't think light weight broadens usable CG range?
Lower loadings = lower angles of attack needed to provide same amount of lift.
So the craft can maneuver at lower angles of attack and will recover to lower angles of attack that is, recover from departure conditions (stalled ) much more readily.
This is not a true statement?
Take any powered plane - fly it - now add weight - keeping speed the same - and see if you can't find the same effect.
eventually it will stall and never take off.
How does lower loading increase CG range ?
It simply reduces the critical nature of the cg --control can become pretty ham fisted in fact .
Attempts at exceeding stall angle have to be really intentional -as opposed to the typical full scale design which must be carefully kept with in the "envelope".
stability can be traded for maneuverability .
I agree with the thought that lightly loaded aircraft are more tolerant of cg position, tho the trim able speed range reduces greatly..the free flight gliders I flew back in the seventies, were built with rearward cg locations and lifting tail surfaces I think speed range is the key factor in this configuration perhaps more so than actual loading, but I wouldnt dare set up a 20 pound gasser like it to find out if I was right
