RCU Forums - View Single Post - Official Traxxas Nitro Sport Thread!!
Old 09-24-2006 | 06:03 PM
dannthenitroman
Default RE: Official Traxxas Nitro Sport Thread!!
Well i dont have the drawn up on the pc but the difference is the front shocktower is not as wide, it is 5mm taller and the shocks are only 20mm apart, and the rear tower is 10 mm taller and also 8 mm wider each side, this as based on the FT GT geometry and will delete most of the excessive droop that makes the sport spin out during constants radius corners and tightening corners. Then the chassis is similar but slimmer and has only a very small carbon upper deck and the full gt steering rack bolts in again giving it much better steering geometry.
Dann
