RE: Wing Attachment Method - Seeking Advice
Both methods works well.. the wing tube method is easier because they don´t need a such well engineered former to support the bracket as long the wing forces are applied on the tube, but this method can´t be used when the turbine installation interferes with it, like a F-15 for example.
So as it said above, this is more about the type of airplane you are designing.
Enrique
