RE: Solartex How to seal?
Balsa USA recommends sealing with polyurethane. What Campy says is very true about letting residue remain when using MinWax Polycrylic. However, if you want to spend the bucks and get a gallon ($42.00 at Lowes) of Varathane Diamond Floor Finsish (water based ploy-u) it will stand up much better than the MinWax. Comes in gloss, flat and satin. I have a wood fuel carrier finished with this stuff. Been using it for 3 years and it is exposed to RAW 15% and I have had zero problems with the finish.
It's what I use and it works for me.
Dan
