ORIGINAL: MikeRuth
I'm going to try the monokote solvent, Interesting they call it "solvent".
Isn't a solvent generally considerd a liquid chemical that desolves another substance?
Mike
That's right...
And so the Monokote solvent melts the edges of the Monokote into the surface, in your instance the bottom monokote, so they effectivly become one. So the edges don't lift.
Use a cue tip or similar to apply it and less is more in this instance. If you put too much on it will mess it up.
Have fun.
Matt
[8D]
