Which Pipe for Irvine .53?
Since your bolt pattern is the same as most other engines in the 46 size range, the sky is the limit as to which pipe you can use. What are your needs?..... top rpms for speed only or a wide speed range for sport flying? Mousse can setups are nice because you can adjust the size of the can and the length easily.
Ernie
