RCU Forums - View Single Post - Global models Tequila Sunrise CG HELP!!!
Old 09-26-2006 | 03:27 PM
duttonflyer
Default Global models Tequila Sunrise CG HELP!!!
Guys I have a .25 size sunrise that I have had built for awhile now but the cg is totally off from what the book says (the book says 2 1/4" +- 1/4 from the leading edge at the center section of the wing). I don't want to pile it up on the first flight because of improper setup. The model is setup with all standard 3004 futaba servoes a custom battery pack that I made to fit this little thing and an older K&B .20 that I had . My problem is that it is way tail heavy I added every lead weight I had for setting cg (about 7.5ozs.) around the firewall and it still didn't come out right. Where should the cg be and where should i set it from? That much extra weight seems excessive to me on such a little plane. The sunrise is only my third plane that ive built so i'm not very knowledgable yet. If anyone has experience with these planes and can help I would greatly appreciate it thanxs.
