Setup for Spectrum DX6 and Blade CP Pro
I switched over to the Specktrum DX6 Radio gear and after a lot of reading and setup I figured I'd pass this info along for the others who may be doing this transition.
When you do the swap and first get it all installed use the sub trims to get your servos centered (horizontal) then adjust the linkages to get your swash plate level.
Here are the settings I used: (I may occasionally edit this as I find better settings)
Model E-flite Blade CP Pro
Model Type:
TYP HE
Data Reset:
1
Dual Rate Switch:
SW CF - Combined Flight Mode Switch
Gear/ Gyro Gain SW:
Ger F - Aileron Flight Mode Switch
Model Sel:
MDL 1
Model Name:
1 PRO
Servo Reversing:
THR Norm
AIL Rev
ELE Rev
RUD Rev
Ger Norm
PIT Norm
Dual Rate 0:
AI0 90%
EL0 90%
Dual Rate 1:
AI1 100%
EL1 100%
Exponential 0:
AI0 5%
EL0 5%
Exponential 1:
AI1 5%
EL1 5%
Sub-Trim: (Set as needed to make your servos centered)
THR 0
AIL -25
ELE -15
RUD +2
Ger +80 (HH Gyro Gain) I am using an Align RCE-500X Gyro
PIT -50
Travel Adjustment
THR -110%
THR +70%
AIL -100%
AIL +100%
ELE -100%
ELE +100%
RUD -100%
RUD +100%
Ger -0% - Set using Subtrim
Ger +0% - Set using Subtrim
PIT -100%
PIT +100%
Throttle Hold:
HLD -1%
Pitch Curve Normal:
PLN 35% -3 Degrees
P2N 65% +5 Degrees
PHN 100% +12 Degrees
Pitch Curve Stunt:
PLS 0% -12 Degrees
P2S 50% 0 Degrees
PHS 100% +12 Degrees
Pitch Curve Hold:
PLH 0% -12 Degrees
P2H 50% 0 Degrees
PHH 100% +12 Degrees
Throttle Curve Normal:
TLN 0%
T2N 65%
THN 100%
Throttle Curve Stunt:
TLS 100%
T2S 80%
Revolution Mixing:
RVU -0%
RVD +0%
Programmable Mixing: Unused
Master CH L
Slave Ch R
Mix Switch Selection: Unused
Mix ASW
Mixing Value Mix: Unused
AXX
Mix Offset: Unused
CCPM Mixing:
CCP On
CP2 + 80% Travel Adjustment for Aileron Function with CCPM on
CP3 + 80% Travel Adjustment for Elevator Function with CCPM on
CP6 + 35% Travel Adjustment for Pitch Function with CCPM on
Trims:
THR 0%
AIL 0%
ELE 0%
RUD 0% Must rebind receiver if rudder trim is changed
It took a lot of reading to find out how the settings on the CCPM work.
Each one of the settings works to adjust the travel for that function ONLY.
I have Aileron set to 80% and Elevator set to 80% this makes for a calmer flying heli.
If desired you can turn these up for a more responsive heli or less for a tamer one 80 seemed good for me.
You also can turn up one or the other ie Aileron 85% and Elevator 95%
Again they are totally independent controls (It took me a lot of time to find this out).
Pitch at 35 controls the pitch if you want less than +/- 12 degrees you would adjust this setting.
Have Fun
