RCU Forums - View Single Post - Strange Problem
Old 09-26-2006 | 11:30 PM
fzeller
Default RE: Strange Problem
O.k. Guys
Let me try to answer your questions. The plane does not bank, It just wants to go straight up. The ailerons have the same deflection both ways. and all throws are what they call for in the book. I will not try to roll it because with my ability as a pilot, if it don't do what it is supposed to, I will need a new plane. That being said, If I measure from the end of the prop to the end of the tail, I get a shorter distance on the right side than on the left. ( If that makes any sense) This leads me to believe what many of you have said. That I have too much right thrust. So I am going to turn the motor to the left, and I will let you know what happens. The weather here stinks, so it might be a while before I can try it.
Thanks again
Fred
