ORIGINAL: buzzlightyear
Hi, I own a JR 6102 Tx, I want to buy a flight pack but I have the choice between FM and PCM. What's the difference? And how can I know wich one my Tx uses?
thansk for helping a newbie!
As for which yours uses, look at your transmitter. If you don't see "PCM" anywhere, then you're limited to the FM (non-PCM) receiver, and need not worry about the difference.
If you see "PCM" on your transmitter, then you can choose either. In your case, I would recommend the Non-PCM receiver.
Best wishes,
Dave Olson
