RCU Forums - View Single Post - JR 6102 Questions
Old 09-28-2006 | 07:27 AM
bruce88123
Default RE: JR 6102 Questions
ORIGINAL: skiman762
So with your equipment and license if you change a crystal and it is transmitting on freq without needing adustment your ok ?
I would technically also require a manual or specifications on the equipment to tell me that I have tested it properly. THEN I would be OK. The point is that you can't just jump into a transmitter and start making adjustments/changes without sufficient knowledge and equipment. You MIGHT get lucky and you might not. Are you willing to bet your plane and those of your friends on it?
