RE: Engine gurus needed
More than likely the crankshft was pushed back a bit when you stuck it straight into the ground. That allows the crankshaft or con rod to touch the back plate causing the black crud. Remove the backplate and using a punch of some kind, stick it into the fuel passage and tap with a hammer. This should drive the crank back forward.
