RCU Forums - View Single Post - elevator control horn question 540T
Old 01-14-2003 | 12:18 PM
vinnie
Default elevator control horn question 540T
Cobra, I had the same problem on my AT-6. While two servos in the tail will work, unless your plane is already nose-heavy, you'll need considerable weight in the nose to balance.
If possible, make a lite-ply pushrod support with a hole a bit larger than the dowel, slide it down the fuselage and epoxy it across a former about halfway down. This will limit side play in the pushrod.
And/or, make a wire joiner and join the elevator halves together anyway, if its not too late.
Good Luck.
