RCU Forums - View Single Post - elevator control horn question 540T
Old 01-15-2003 | 02:06 AM
Mike Rojas's Avatar
Mike Rojas
Default elevator control horn question 540T
If you have room up front,you could put two ele.servos up front with two pushrods.I really don't like adding weight to a plane,if it were me I would put two Hitec HS 225mg mini servos in the tail,with a pull pull set up on the rudder up front.It really depends on how the model balances,with a glow engine up front you should be able to move all your radio eqipment up front to offset the balance.The two 225's are about equal to one standard servo.JMO
Mike
