RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair
Rcpiolt78 That tail group looks resly goodand with it solid in the rest of the structure,you shoulr be okjuxt csrefullwith thr epoxy
Cimsrs my stabhas about 2pos deg at leading edge. one ie=s abiut the same i have to admit I used 2 robsrt meterd jigs and a 4'netal scale to get tvery thing the way the plans cald for.every thing was weighted downwith bsbby sochs filled with #6 led shotso nothing moved inless you movedit.
If you change the balsa at the top of thr rudder, use the hardest balsa you can finc.add a piece of 1/64 acply to thr sides snd back of to fin post this will help on nose over
Went looking for the book,at this point it probly went in our hose fire 25 years ago. OH Well..
Got somthing done for a chsnge the iso block is milled to s msx thickness of .542 will finaly be taking it for taxy testat least sat/sun
Cheers bob T
