RCU Forums - View Single Post - winter break in
Old 09-29-2006 | 04:43 AM
KillerKiwi
Banned
Default RE: winter break in
ORIGINAL: Takedown
Or you can wrap a small towel aroung your engine cooling head then put aluminum foil wrap around it. also keep the fuel lines worm if any way possible just wrap the fual lines with that heat hand warmer stuff so that they wont crack and do the same with the tank.
That's exactly what I said.
It is most important to keep the fuel warm so it doesn't gel up.
