RCU Forums - View Single Post - Thunder Tiger PRO nitro problem 'help'
Old 09-30-2006 | 07:23 AM
DarZeelon's Avatar
DarZeelon
Default RE: Thunder Tiger PRO nitro problem 'help'
About the phenomenon; I have seen this happen; you throttle down and the engine hangs at 4,000-4,500 RPM for some 10 seconds, before dropping to idle...
I think the engine I saw do this was too rich on the low-end mixture.
In most cases, this only causes a fading idle and a 'burbly' recovery to max RPM (if it eventually happens), but that engine had that 'hanging' before drop-down.
Mick; it certainly is not a nitro related problem!
