ORIGINAL: Cali11
I like to come in hard and fast.Just before it gets to me I pull back hard and loose all the air under the plane.Plane just falls to the ground.Makes for a perfect easy landing.Looks like you dropped it from about 2 feet.
How do you stop the plane from climbing when you pull back? Or do you pull back so hard that the plane goes instantly vertical and the body is pretty much a wall against the air to slow it down?
I also like doing barrel rolls as I climb.
Do you pull back to get your nose up and then just roll? When I do barrel rolls my nose loses a little altitude with each roll.
