RCU Forums - View Single Post - How do you stop your engine?
Old 09-30-2006 | 10:59 AM
jnev
Default RE: How do you stop your engine?
I usually touch the stinger.. it's convenient because usually the only reason I shut it down is because I forgot something, so it makes starting it back up easier. I use the flywheel if I've had a runaway and the engine is still at full throttle or something because then there's a ton of exhaust coming out the pipe...
