Originally posted by raabid
Thanks, I played with the trims a little my last flight out but got a little too absorbed with it a took a nose dive. I don't have mixing capabilites although that sounds like a great help. Should I trim the elevator at full throttle or slow the engine down for level flight?
I personally trim the elevator for level flight at the throtle setting I plan on using the most while flying With my non-computer radios.
As I said with my computer radios I use the mix that way I get level flight at most throtle settings
You do have to be carefull that you are paying attention while trimming. Thats why I get the plane up about two mistakes high
