RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair
Sorry rt3232 but did you say you set the stab a 2 deg pos ? If so did u also set the wing at the same ? i also found the cloth covering should have searched tower before I asked ?last question was reading a head in the instructions getting close to needing servos what do yall recommend ? should i go with metal gears or is the composite gears fine and should i go with metal control arms ?
