RCU Forums - View Single Post - Pressure Tap
Thread: Pressure Tap
Old 10-01-2006 | 01:28 AM
proptop's Avatar
proptop
My Feedback: (8)
Default RE: Pressure Tap
Generally, tank pressure is taken off from the muffler...
You can also use case pressure...it will be greater, but muffler press. is usually sufficient.
Most mufflers have a press. fitting...what type engine are you talking about?
edit: one thing better about muff. press. is that if there is any back flow, it will have less chance of flooding the crankcase w/ raw fuel if the line is connected to the muffler.
