Do you think i could get and x50 and sufficiently power it with the fl70
With a 13-6 prop i can hover at 75% power
I could probabley even slip on a 14-wood prop
It should... I had the older Funtana 40(hated it) and still have the Funtana 90(not bad) The older funtana 40 came out heavy for the size and flew so... I think your Fl-70 would have been marginal... IF horizon has the weight close and you can end up right at or even under 5lbs you should do fine with your Fl-70 on the nose running an APC 13x6. Check out the 3D forum... there is a build thread on the Funtana X 50.
John
