RE: megatech nitros
Well I cant tell you about the cars but I can tell you about there engine's as I have one. They can be hard to start but easy to tune. Not a whole lot of power behind the M16 engine. Good enough to spin the tires on a 2wd st but then again just about any engine can spin the tires on a 2wd buggy. Not a whole lot of torque on the bottom end and is kinda slow in the middle and not a burner by any means on the top end. It's not a bad engine but not the fastest engine out on the market. Now I used to higher powered machine such as a .12cvr when I was racing and a .18cvr. It will get a st up and running good spinning the tires on dirt.
If your looking to buy that car that engine would be a good engine for that car, you may have some difficultes in finding replacement parts at your LHS. And dont expect the 55 mph speed's that they have posted there. I would expect speeds of about maybe 25 to 30mph and not much if any more. Maybe someone else car tell you about the car itself though.
