RCU Forums - View Single Post - Pressure Tap
Thread: Pressure Tap
Old 10-02-2006 | 01:30 AM
jetpack's Avatar
jetpack
Default RE: Pressure Tap
I haven't counted out a perry system, and your point about the vent taking in water I considered also. The carbs do need pressure per instructions, I was just trying to get away with a more simple closed system which by others the webra's only been needing pipe pressure and a good tank location.
The vent I guess could be delt with just simply pointing it upside down in the boat, or a snorkel where when its capsized would clear the waterline.
So with the vent problem solved Im going back to the ideas again.
