RCU Forums - View Single Post - nitro or electirc?
Old 10-02-2006 | 02:03 PM
Auslide
Banned
Default RE: nitro or electirc?
ORIGINAL: WalawalaStore
Hi,
IMO, Nitro seems to drift better than electric because of no clutch engagement at low engine rev. The rear tend to swing more freely.
Regards
Joaquim
There is No Clutch engagement at Low RPM on an Electric, Power is there from the Get go ..
EG More Responsive..
Your over looking the Key Essentiual factor for Drift, Low Speed Controlability..
No Use having all This Grunt if the Clutch has to engage before you can even use it..
The Best Drifters in the World Use eletric motors Rated at Around 23Turns, Why??
Because you dont need to be Going Flat out, Infact the Slower your going the Wider the Angle the more realistic the Drift..
