ORIGINAL: timothy thompson
there is a post in the crash section about club members purposly shooting down a trainer with airsoft pellet guns isnt this againt ama code
Go find it and report back.
I don't recall shooting at models as against the code. There is something that disallows the aircraft from firing projectiles as an AMA member. If you’re not an AMA member you are
FREE to fire off rockets from R/C planes if you wish.
You know Tim, no one is
forcing you are anyone else to participate. If you find yourself in an environment that you
feel is too dangerous simply leave but please refrain from yelling the sky is falling, the sky is falling.
Believe it or not there are people that think flying models are dangerous in of itself but as we all know people jump out of perfectly good flying airplanes all the time for the thrill. Sure it could be argued that they did not even need to get into the airplane much less jump out. Danger and risk is part of
living…
your war birds could be rubber powered to make them safer but………………………………………†¦â€¦â€¦â€¦â€¦.
Get over it!
