ORIGINAL: proptop
Did you also use some rudder with the aileron? Usually, an airplane of that type will roll quicker if you also apply rudder in the same direction...
Try it up high for the first few times and see if it works.
i did use rudder, it helped a little but not much, and even my instructor said it could use some more roll. but thanks for the tip.
