RCU Forums - View Single Post - Pressure Tap
Thread: Pressure Tap
Old 10-03-2006 | 07:03 AM
Hobbsy's Avatar
Hobbsy
My Feedback: (102)
Default RE: Pressure Tap
Chip has the perfect idea, using the Cline or IronBay regulator not only will you have completely closed sytem but you'll have uniform engine performance from full tank to empty. You can also run the engine a little leaner because you don't have to run it rich at the beginning of the tank to prevent it from being lean when fuel level gets low.
