RE: F-16 Falcon Balance Issue
Well, from reading the post you have indeed done your research. The only thing I can think of is a reversed prop (on a pusher the lettering should face the front of the jet). You probably knew that, it just was a long shot. If you feel comfoartable doing this, give it a try: Get a tablet scale or a kitchen scale and place the nose on the scale, pay attention to the weight. Carefuly give it full throttle and check the weight again. If you get anything under say, 10-15 oz of thrust, you have a motor/batt issue. Good luck!
