RCU Forums - View Single Post - Pressure Tap
Thread: Pressure Tap
Old 10-03-2006 | 03:50 PM
ZAGNUT's Avatar
ZAGNUT
Default RE: Pressure Tap
ORIGINAL: Artisan
When running crankcase pressure, a one way valve must be used, otherwise the end result is no pressure at all, since the piston goes up and down, causing the pressure to swing from positive to negative to positive over and over again.
you left out the part about the intake valve being open for most of the time that the piston is going up....
dave
