Biodiesel
Ray, Clarence Lee said there was no mention of ether in James Tasman's claims, so I tried it with only a little Lawnboy oil added for lube. It did fire and blow smoke rings then kicked the prop off, by this time I was nearly frozen as it was very cold here in Va. I suspect that because it was so cold I had the engine overcompressed. I'm going to try again on a warmer day, also I'm going to run the PAW, it's a .60, on RedMax diesel fuel to set the engine up again to have a base line. I'll keep you posted. Bob Davis has bought some and is going to see what he can do with it.
