RCU Forums - View Single Post - The Mosquitos are here!!
Old 10-03-2006 | 10:38 PM
  #31
micro_builder's Avatar
micro_builder
Default RE: The Mosquitos are here!!
check the gears. the upper gear sometimes loses contact with its pinion. this is pretty common, and quite easy to fix. you'll notice on the pinion there's a few very small grooves on the outer edge, this is where the spur gear slips back into the pinion. i wouldnt play much with the other SW POTs, its pretty easy to get things out of whack with those.
nick
