RE: evolution 45gx2 spinner back plate
George,
Not only the spinner back-plate needs to be drilled for the prop-hub's bolt-pattern, but also the prop itself.
The prop must be drilled so it is mounted at a convenient angle for the starting fling.
With the new ignition system provided by MVVS for their gas engines, this is a bit less critical, but you would still be more comfortable if the prop blade is at about 1 o'clock before it is flinged to start.
If the spinner's back-plate isn't keyed to its cone, this is not a problem...
