RE: The Mosquitos are here!!
They look fine, and the blades are spinning. I should of explained it better.
I turn everything on, and then take off, it will go up to the ceiling so I let off the throttle and bring it back down to 2-3 ft above the ground. It just starts spinning like one motor is getting all of the power. It spins to the right. So I give it full left trim and turn the stick all the way to the left. It still is spinning pretty fast. Sounds like I got another bad one.
Edit: The whole time it's spinning, it is in the air.
