ORIGINAL: rickye
I was wondering if anyone could help me, i recently got a volcano sv, and im new to nitro motors. Ive been trying to tune this thing in for over a week now, and I can get it to run, but it stalls when I break, when I get this fixed, it stalls when I gas it. So now Im back to square one, any advice would be greatly appreciated.
sounds like your transmitter and idle are not set up correctly. you need to set your trim to nuetral (center), then adjust your carb so it only open 1mm (clockwise is to open c clockwise is to close). the trim shouldnt control your idle. make sure when you give it some brake that the opening in the carb doesnt close too.
your low end should be even with the collar and the high end should be 2-1/2 to 3 turns out.
Hope this helps.
