RCU Forums - View Single Post - drifting nitros
Old 10-04-2006 | 10:14 AM
rct
Default RE: drifting nitros
ORIGINAL: NarutoME
what size are your wheels? the stage d hpi tires are 26 front and 30's on the back. read your instruction manual for proper size or get a ruler and measure them or replace wheels/tires with one's that fit your car.
or what you could do is make some diy offsets and then they should not hit the arms!
no before people start saying that once you have made diy offsets you cant put rubber tyres back on! this is rubbish as i ahve done it and it all depends on the typr of rim that you addapt.
to be honest i can make most rims into diy offset's and still run rubber tyres on them.
the modifications are simple.
if you need to knwo more just ask and i will do a detailed tut.
