RCU Forums - View Single Post - mildew problem
Old 10-04-2006 | 05:48 PM
agexpert
Default RE: mildew problem
Well,
Depending on where it is, your plane may be done. If not now, soon. Check to see if the wood is weakened, or if the covering is coming off. Mildew needs moisture. Dry it out with a heat gun and use rubbing alcohol to kill the mildew. Bleach is 98% water and will just make a soggy plane that smells like a public pool.
