RCU Forums - View Single Post - CT-5 suspension help!!!
Old 10-04-2006 | 10:31 PM
CEN Racing's Avatar
Default RE: CT-5 suspension help!!!
To adjust the CT4/CT5 shocks you simply need to add or remove shims from the spring. These shims are plastic and can clip in and out to adjust the ride height.
Normally you want the front to sit a bit higher than the rear. This helps with steering in sharp turns (has to do with the roll centers of the car).
Hope this helps.
