Originally posted by Crashem
A word of advice the thunder Tiger 40 I had several years ago had metric hardware not standard. If you try to use a 2-56 clevis with a metric pushrod the clevis can and will come loose during flight.
Also the fuel tank should go behind the firewall not in front of the servo tray. Trim the bulkheads a little at a time until it fits.
BTW I thought it was a get flying plane right up to the point that I flew it through a tree!!!
now this is what I'm talking about? Thanks Crashem. About 1/2 way done. Doing the tail feathers today. Hey did yours have a plastic motor mount? My kit came with one. Should I buy a upgraded on. There are also no holes for the motor, you must drill them yourself. Just thought it was weird because the pic in the directions show a metal one with pre drilled holes. No biggy but just wondering. I also used Dubro connectors as well. To much easier to make adjustments.
