http://us.st11.yimg.com/us.st.yimg.c...e_1917_1703845
Anybody own these tanks?
Hobbico 1/35 R/C Combat Armor Tank Set (2)
This is a pair of 1/35 scale electric powered, radio controlled Hobbico Combat Armor Tanks.
FEATURES: An Interactive Battle system on each tank allows user to shoot a beam of infrared light as the cannon roars, the muzzle flashes and the tank rocks back on its treads, the target is a sensor located on top of the opposing tank's turret that stops the tank when hit, three hits on the sensor will disable the tank for a period of five seconds before being able to be restarted from the controller Tanks start up with a push of a button on the transmitter which controls a motor for each track that allows for forward, reverse, left, right, and even 360 degree pivot turns Tanks are scale replicas of the German King Tiger and include details such as correct tool locations, markings, insignia, and camouflage patterns Two different radio frequencies allow tanks to be operated at the same time
INCLUDES: Two Hobbico Combat Armor Tanks with one 27MHz and one 49MHz transmitter
REQUIRES: Six AAA batteries for transmitter, use 1 FUGP7404 and 1 FUGP7400 One 9V alkaline battery for each tank use 2 FUGP7600
SPECS: Length: 8" (203mm) Width: 4" (102mm) Height: 3-1/2" (89mm)
not a bad scale to own for the size..
