Well, I was hovering the CP pro around indoors tonight and I had set it down and left the battery plugged in and the transmitter on with full batteris while i went to grab a drink. I take like 5 steps away from it and I hear a gently whir, a few ticks, and as I turn around I see smoke coming from the heli...
I unplug the battery asap, but by then the tail motor wires are melted and the 3 in 1 is fried.
Somehow, the tailmotor must have kicked on full but the main motor didnt and it fell on its side and the tail blades got jammed on the floor.....
So the main motor seems fine and wanst hot, but the dual tailmotors are dead (one for sure) and the wires melted and when I went to pull the tail motor wires from the 3 in one, the posts form the 3 in 1 came with the wires
So, Does anyone have any idea what happened??? The transmitter didnt move, it had the antennae up and the throttle stick down, wasnt in idle up. I have super skids on the heli and the antennae wire was run through the antennae tube and hasnt given me any glitches before. The batt was at about half life or so.
the transmitter was set about 10 feet from the heli.
any ideas?
And also, I guess I need a new 3 in 1. Is there a better one to get han replacing stock ofr stock, or should I stick with the eflite one?
Thanks!
